Kod: Zaznacz cały
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit
Address 08 -------------------------------------------------------
Controller: 6Q0 820 045
Component: Klimaanlage X0840
3 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
28-00 - Short to B+
29-10 - Short to Ground - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25758
Shop #: WSC 00788
2 Faults Found:
00906 - Horn (H1)
28-10 - Short to B+ - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 820
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01141
Shop #: WSC 00000
WVWZZZ9NZ3Y091899 VWZ7Z0B5699390
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 08 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 00788
No fault code found.
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 4R Komfortgerát 0002
Coding: 00064
Shop #: WSC 00788
End -------------------------------------------------------
