Nw.błędy kasuje się i potem logi są czyste, do następnego razu
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
Address 01: Engine Labels: None
Part No: 03D 906 023
Component: SIMOS91 1.2l 2V 5414
Revision: --H04--- Serial number: VWZ7Z0H6690420
Coding: 0000071
Shop #: WSC 00788 785 00200
VCID: DBB1135F61E5
No fault code found.
Readiness: 0010 0101
Address 03: ABS Brakes Labels: None
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002082
VCID: 810D0137A3C9
2 Faults Found:
01201 - ABS Valves Supply Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 5
Reset counter: 145
Mileage: 196756 km
Time Indication: 0
00301 - ABS Return Flow Pump (V39)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 5
Reset counter: 145
Mileage: 196756 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 6Q0 820 045
Component: Klimaanlage X0850
VCID: EADF469BBEBF
2 Faults Found:
00898 - Control Circuit A/C compressor
30-10 - Open or Short to Plus - Intermittent
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 25742
Shop #: WSC 00788
VCID: 3E773ACB12B7
2 Faults Found:
01309 - Power Steering Control Module (J500)
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Address 15: Airbags Labels: None
Part No: 6Q0 909 601 F
Component: 05 AIRBAG VW5 0010
Coding: 12341
Shop #: WSC 00788
VCID: 366722EB3A87
Address 17: Instruments Labels: None
Part No: 6Q0 920 804 X
Component: KOMBIINSTRUMENT AGD V04
Coding: 01131
Shop #: WSC 00420
VCID: 4687522B4A67
2 Faults Found:
Address 19: CAN Gateway Labels: None
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 00788
VCID: F0EB54F39863
2 Faults Found:
Address 25: Immobilizer Labels: None
Component: IMMOBILIZER AGD V04
Coding: 01131
Shop #: WSC 00420
VCID: 4687522B4A67
WVWZZZ9NZ8Y216137 VWZ7Z0H6690420
Address 44: Steering Assist Labels: None
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10140
Shop #: WSC 00788
VCID: EDD54D878F51
2 Faults Found:
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
01288 - Terminal 30; Steering Assist
07-10 - Signal too Low - Intermittent
Address 46: Central Conv. Labels: None
Part No: 6Q0 959 433 H
Component: 1D Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 408B44336843
Address 56: Radio Labels: None
Part No SW: 6Q0 035 152 G HW: 6Q0 035 152 G
Component: Radio LG3 0014
Revision: 00008000 Serial number: VWZCZ5H0008996
Coding: 0020200
VCID: 2E570A8BC2D7
End ---------------------------------------------------------------------
[quote="darekkow"]Porównaj nr regulatora napięcia[/quote]
Te same.
Przed chwilą włożyłem 3-ci alternator (wiem, to już szaleństwo), który był sprawdzany na stole pomiarowym i jest na 100% dobry.
