Chciałbym was prosić o pomoc w identyfikacji błędów w moim VW POLO 9N
Kod: Zaznacz cały
VCDS-Lite Version: Release 1.0
Wednesday, 29 October 2014, 16:55:38:0
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,45,46,56,76
Address 01: Engine Labels: Redir Fail!
Controller: 03D 906 032 T
Component: 1,2l/2V SIMOS3 00HS2508
Coding: 00031
Shop #: WSC 45641
WVWZZZ9NZ3Y216128 VWZ7Z0B6369031
2 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q0 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 17420
Shop #: WSC 25003
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 K
Component: 0K AIRBAG VW51 0N 0006
Coding: 12363
Shop #: WSC 00788
No fault code found.
Address 17: Instruments Labels: Redir Fail!
Controller: 6Q0 920 800 Pu
Component: KOMBI+WEGFAHRSP VDO V15
Coding: 01131
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: 0008 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 25003
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.LBL
Controller: 6Q0 423 156 Q
Component: LenkhilfeTRW V250
Coding: 10140
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
